Configure the value of the PTP announce interval time on the port(s) for sending announce messages. This command is available only for boundary and ordinary clocks. The interval time is the time between successive announce messages.
| boundary | Boundary clock instance. |
| ordinary | Ordinary clock instance. |
| seconds_log_base_2 | The log base 2 value of the seconds between successive announce messages. For example, to specify 8 seconds, use 3. The default value is 1, and the range is -2 to 4. |
| vlan_name | Name of the VLAN to apply the command to. |
The default value of the announce interval is log base 2 (1), or 2 seconds.
Use this command to configure the value of PTP announce interval time on the port(s) for sending announce messages. The announce interval is set using log base 2 values. The range is -2 to 4. This command is available only for boundary and ordinary clocks.
The following example configures announce interval to be 1/second on the clock port lpbk-gm of the ordinary clock:
# configure network-clock ptp ordinary announce interval 0 vlan lpbk-gm
The following example configures announce interval to be 2/second on the clock-port lpbk-gm of the boundary clock:
# configure network-clock ptp boundary announce interval -1 vlan lpbk-gm
This command was first available in ExtremeXOS 15.1.
This command is available on 7520-48Y and 7720 platforms.
PTP commands can be used only with the Premier license pack.
